boji
Re: API 2503 transformer
« Reply #20 on: July 04, 2019, 08:09:12 AM »
So comon, iprovlek!   Lets see some more pr0n in action!
« Last Edit: July 04, 2019, 09:29:23 PM by boji »
iprovlek
« Reply #21 on: July 04, 2019, 10:17:30 AM »
Be patient Boji....
CJ
« Reply #22 on: July 06, 2019, 04:17:58 AM »
if you use a twist drill, you can time the amount of time the drill runs at the same speed (why not flat out?) to give you the same twists per inch,
using twisted wire instead of quad means you will get the same results no matter which leads you use for color coded hookup wire,
with quad you might be using the two inner wires for pri, or two outer, or 1 and 3, get it?  capacitance might be a little \different between wires, not so with the twisted wire,
If I can't fix it, I can fix it so nobody else can!
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
abbey road d enfer
« Reply #23 on: July 06, 2019, 04:36:08 AM »
Considering the mean turn length of about 4 inches and the total wire length of about 200 ft, a good enough precision can be attained by just looking at the coiled wire.
Who's right or wrong is irrelevant. What matters is what's right or wrong.
Star ground is for electricians.
Last post December 10, 2007, 12:52:10 AM
by outoftune
Last post October 08, 2008, 08:00:31 AM
by raysolinski
Last post March 27, 2013, 01:32:25 AM
by abbey road d enfer
Last post June 17, 2019, 09:25:35 AM
by gyraf
