imanerd808
Member
- Joined
- Apr 1, 2019
- Messages
- 5
I soldered R14 wrong on one of my DIY-990 op amps and when powering up it started to smoke. After looking at the board I see that R36 is burnt. looking at the DIY-990 I found R14 backwards and the resistor pushed up against the MJE171G transistor. If I swap the orientation of the resistor and replace R36 should this fix the problem? is there a chance I screwed up the Transistor? or both transistors? any help would be appreciated.
