Popping from EQ in/out switch
Potato Cakes
Nashville, TN
Hello,
I have several of the Audiox's 169 preamp/EQ modules I built a while back where I added all the options I could in a single 500 series module. All of the features work as intended, but there is a bit of a thump/pop when switching the EQ in and out (EQ bypass is not built into the original circuit). I know there's a simple way of solving this with either a resistor or capacitor either between switch poles or between a pole and ground I just don't know exactly. These modules are working and I'm wanting to avoid what sometimes does in my DIY world where I cause more problems and headaches while trying to find what should be the simplest solution. If someone who knows could give me a hint I think that would allow me to avoid potential unnecessary frustration.
Paul
I'm using a toggle switch to jump around the EQ circuit as the preamp section still has to be in play. I think I might be getting DC from somewhere, but didn't know where the best place to do the blocking would be. I'll look around for the overlay and the points I used for signal to the switch to see if that clarifies what I'm doing.
Paul
There is no one single common cause for a switch causing popping. Post a schematic of the switch and the components connected to it.
And here are the board edits.
Upon looking at this, I'm not sure why I removed C15 and put it at the end. I probably should have just left it in there and added another coupling cap. I was some time ago and I've worked on a bunch of stuff since then so I can't quite recall my thought process during this project.
Paul
  • 169 Board Edits.pdf
Since I have raised the question, I believe I have found the error of my ways. I've learned a couple more things since I built these, and looking at the schematic now I have no idea how I ended up with what I did to insert an EQ bypass let alone how it even worked.
I pulled C15 and put in a jumper and then picked off from the + connection of C15 and went to the switch pole. From there the two toggle positions  went to the output of U2 and the other went to a negative connection of what was C15 and the positive side of that connected to the junction of R34 and R32. I don't know why but looking at this now I can see this is very wrong.
I'll do a drawing of the schematic of what I think I should do and post that for review.
Paul
This is whats done in true bypass guitar pedals,
adding 1Mega resistors to gound, maybe you could try that out:
check the full article here:
http://www.muzique.com/lab/pop.htm
That was going to be my next thing to try after I make corrections to my initial work.
Paul
Potato Cakes said:
.I pulled C15
That's your first mistake. You should have left it there.
You should take the PRE-EQ signal from junction of C14 and C15. BUT...
Indeed. I would recommend you put it in its original state because the second EQ stage is also one -half of the output stage. You would need an extensive mod of the topology to achieve your goal.
[/quote]
Yes, all very wrong indeed.
As I mentioned as stared at the schematic again and it became clear what the majority of my mistakes were. I'm going to try to get at these this weekend and correct my mistakes and see if that solves the switching noise.
Paul
I've gone back and reinstalled C15 from the schematic and made the switch connections as attached. The popping seems to have been solved, however I now have a noticeable gain difference between EQ in and out as well having a high frequency roll off starting around 1k no matter if the EQ section is in or out. With the other builds that still have the incorrectly wired bypass mod, I get a roll off starting around 16k. The EQ still seems to function as it should, but for some reason their is a fixed HF attenuation around 1k. I'm afraid I may have opened a whole can of worms. I'm going to make corrections to one of the other modules and see if I get the same results.
Paul
  • 169 EQ Bypass.pdf
It's just not the way bypass is done. Your bypass position actually loads the preamp's output with the EQ's output. You would need to disconnect the 100uF that's close to C24 to fix that. However, the EQ network would still interact with the frequency response. As I said earlier, proper bypass needs a significant change of topology.
I agree that isn't ideal as I am trying to find a way to do this without ripping apart the whole board and starting over. I've started a new thread that pertains to creating a bypass since the popping sound has been resolved.
https://groupdiy.com/index.php?topic=72410.0
Paul
