spring reverb balanced > unbalanced debugging
brndvnrdn
Active member
Amsterdam, Netherlands
Hoping someone can impart some wisdom.
I am making a spring reverb unit, and first had a working prototype that used an unbalanced in and output. After that I wanted to add some features (relay switching bypass, balanced in and out).  The bypass works great, but am having some trouble with the unbalanced balanced part of the circuit.
I used a part of the ssl mixbus schematic for the balanced to unbalanced conversion and vice versa. Something seems to be going wrong, because I am getting a lot of distortion/high output level from the output of the spring reverb.
When I bypass the spring section of the schematic I get a high boost in volume as well.
Nope, same problem with different ic's unfortunately. Any other ideas ?
edit : hmm, the tl074 now seems to be getting hot as well (didn't happen before or i didn't notice it). maybe it's oscillating in a high frequency or it has a big load on the output?
