electric_diaries
Hi All.
I have just started thinking about the in/out circuitry on a simple VCA design and I have, but I can’t quite get my head around it. I don’t usually work with balanced signals anywhere in my chain so please bare with me.
I was thinking about using something similar to Gyraf’s SSL compressor circuitry using standard op-amps, but I need the signal to be normalised to 0dB (from input to output) regardless of wether the in/out signal is balanced or not.
In my head I see a 6dB loss at the input when plugging in an unbalanced signal/cable, and another 6dB loss at the output if I plug in an unbalanced cable. So we are talking about 12dB loss if I use unbalanced signals. Are there any circuits out there to mitigate this loss when an unbalanced signal/cable is plugged in?
Here again a brief explanation of the two possible scenarios:
Scenario one:
Balanced TRS in/out plugs, interfacing with other balanced gear.
Scenario two
Unbalanced TS in/out plugs, interfacing with other unbalanced gear.
thanks!
Scenario one:
Scenario two
thanks!
