Input Pad that changes impedance?
Potato Cakes
Nashville, TN
Hello,
I'm working on a couple of preamp/EQs and while doing initial testing I thought I was having an issue with the noise floor, but it turns out there was an impedance mismatch between the generator (line level) and the preamp. When I connect a microphone or my battery powered handheld generator I do not have this issue. I have selectable H-pad installed to allow the preamp to handle line level signals so I can use the EQ for mixing, but this won't do me much good currently as the noise level with the impedance mismatch is the same regardless of the pad being in or out. So I'm wondering is there a different type of pad that could be implemented  which would also address the impedance/noise issue? I'm working within the parameters of the existing board and design, so essentially I have to be able to do this with the existing DPDT switch that I am currently using for the pad. I know that this can be done at the input transformer and a number of other ways if I was building this out as a new project, but this would require more alterations to the board and metal work than I am willing to do for these particular preamps.
Paul
Any resistive pad will include loss of signal and noise, the way to do it (RF Style) would be to use reactive elements, in audio thou, more frequently you can use a transformer, a 4:1 ratio  should suffice to attenuate the level. I still dont know whats the "mismatch" issue with your setup, audio is mostly impedance bridging instead of matching, as long as the output Z of the equipment is much lower that the input Z of the other equipment you shouldnt have any problems
You dont mention the output Z of your generator or the input Z of the preamp, when you say that you want to match them you mean that you want the reflected impedances to be the same? like 600 ohm to 600 ohm?
If you insist on using resistive pads instead of transformers, there are quite a few that you can use in the book "Handbook for sound engineers" by Ballou
Potato Cakes said:
Hello,
Paul
H-pad is probably not the best option.
Post schematic of said H-pad.
I'm using an Aurora(n) as the signal generator. The manual doesn't list the output impedance for the Line Out modules, but I'm guessing it's around 150ohm like what I have seen for modern digital consoles. The transformer is a Neutrik NTM4 which is 200:10k, so that is why my first reaction to the noise is an impedance mismatch. I also can't seem to find information on the NTM4 windings to figure out how the impedance would change with changing the primaries/secondaries from parallel/series. But again, this would require another switch and making unwanted alterations to the board (unwanted = more work).
For a balanced connection, the only resistive pads that are applicable that I am aware of are H and U. The H pad I am using is working as intended and gives me the desired decrease in gain, but the noise floor does not change when a line level source is connected.
Paul
Attached is the H-pad in it's current configuration. It's on a DPDT toggle switch which is not shown on my crude drawing. It does give me the 30dB of reduction which ends up being unity gain with the gain knob all the way down and the pad engaged. As mentioned before, with a line level source (the Aurora(n) I am using) the noise floor remains constant with the pad switched in/out but the signal is affected as intended. With a microphone or other similar impedance the noise floor is decreased dramatically to what I am expecting. Ideally when I engage the pad it would increase the impedance to match a line level source better in addition to attenuating. But as I'm thinking about the whole scenario related to this circuit I don't see how that would be possible without a second mechanical action.
Paul
Paul
I don't know how you set for these values but it seems wrong to me. It looks like it provides about 15dB attenuation, but its output impedance is approx. 800 ohms, which explains why the noise doesn't change. OTOH, the input impedance is about 200r, which loads the output of the Aurora in a prejudicial manner. I believe that's where the additional 15dB of attenuation comes from.
You should use a U-pad wit about 5k in series with each leg (which would result in about 10k as a line input), and a 330 r as shunt.
First, one should know I built these a while back with the even more limited knowledge I had back then. I had borrowed the values for what was supposed to be 20dB, then I put a trimmer in for the shunt to and adjusted it until I got 30dB of reduction.
I will give your U-pad values ago and report back.
Paul
The U-pad did the trick. I did have to change the shunt to 200R to get to 30dB of reduction, but the noise is now minimized, making it very quiet when doing some listening tests. Thanks so much for providing me the resistor values to use. Now on to the last issue I'm trying to resolve with these 500 series modules I have going on another thread.
Paul
