SSL Alpha Link MADI AX with MADI Extreme 64 PCI card -SOLD
zqone537
Up for grabs is a my SSL Alpha Link.
Located in Sweden
Paypal
Top converters and the best value for up to 64 inputs and outputs. It’s in next to new condition. Also included is the MAdixtreme 64 PCI card and a MADI cable as well.
Any questions you may have do not hesitate to ask.
Info on SSL Alpha Link:
The Alpha-Link MADI-SX and MADI-AX are well established as reliable high quality multi-channel audio converters in professional studio installations around the world. Both models feature 64 channel MADI to 24 channel digital and 24 channel SSL A-D/D-A converters.
Each unit features lossless Fibre Optic MADI In/Out connections which can be used to connect to SSL’s own MadiXtreme, MX4 or Delta-Link computer interfaces, to MADI equipped consoles and routers or to cascade multiple Alpha-Link units to create powerful systems that offer exceptional value.
The MADI-AX provides 24 ADAT Lightpipe digital Inputs and Outputs.
It also feature a front panel hardware switch based control interface with LED status indication, and dedicated tri-colour LED’s provide signal activity indication.
24 analogue
Up to 64 MADI digital
High quality SSL A-D/D-A converter technology
Lossless 64 channel Fibre Optic MADI digital audio input and 24 analogue inputs and outputs with SSL A-D/D-A at up to 96kHz
Rear panel analogue connection via standard 24 pin D-Sub
BNC Word Clock sync In/Out
Perfect partner product for SSL MadiXtreme, MX4 and Delta-Link interfaces
All input and output channels can be used simultaneously in any configuration
Comprehensive input/output routing & mode selection matrix
Operating voltage: 100-240VAC, 50/60Hz
Power consumption: 30W
MIDI (Number of ports): 2 (1 input port and 1 output port)
Phones connector style: 1/4" JACK
Depth: 310mm
Height: 88mm (2RU)
Width: 19.0"
Weight: 6.0kg
