DaveP's Attenuators
letterbeacon
London, UK
I find the way DaveP lays out his attenuators very easy to understand - here's an example of his one for his BA-6A:
What sort of attenuator is this? A T Pad? What's the best way to calculate the values if I wanted to build something similar on a 6 position rotary switch?
Thanks.
So, if I'm after a 600r attenuator, as long as each leg adds up to 300r then it'll work?
Are there any advantages/ disadvantages of a U pad over a T pad?
In a U attenuator you have 3 or 4 resistances, 2 of them to a common point like in your circuit, if you want a 600r output, you need that the Thevenin resistance be 600 ohm, not only making 2 of them 300 ohm, in other words you need to consider the shunt aswell as the series resistances in the calculation for output impedance. For 600:600 attenuators check the book "Handbook for sound engineers " by Ballou
