RuudNL Well-known member Joined Apr 26, 2009 Messages 3,113 Location Haule / The Netherlands May 21, 2019 #1 Should a 500-rack module have a balanced output, or is an impedance balanced output sufficient? What do most manufacturers do?
RuudNL Well-known member Joined Apr 26, 2009 Messages 3,113 Location Haule / The Netherlands May 22, 2019 #2 I see for example that some DBX modules have a balanced (OpAmp) input, but an a-symmetric output, the '-' output even connected directly to ground.
J john12ax7 Well-known member Joined Oct 15, 2010 Messages 2,470 Location California, US May 22, 2019 #3 I see a lot of transformer outputs as well as THAT 1646 type driver stage outputs. Impedance balanced would be fine as well.
Meathands Well-known member Joined Feb 6, 2009 Messages 319 Location Philadelphia May 23, 2019 #4 Yep, it's pretty all over the map. I've seen several single-opamp, impedance balanced outputs on 500-series modules. At least they play nice with unbalanced inputs.
