RCA BA-6A Release Mod
letterbeacon
London, UK
Hi there,
I’ve built an BA6A pretty much stock, apart from a threshold control, and I would now like to mod the release.
I suppose the easiest thing would be to add a couple more positions on the rotary switch, but would it be possible to add a pot so I can more precisely control the release?
Would it just be a case of replacing the resistor in the timing circuit with a pot? If so, which value should I start with?
Thanks a lot.
You'll need to pick the pot by ear and I recommend an end stop resistor to make a minimum value above 0Ω, unless you want 0Ω to create a GR bypass position.
One problem you'll encounter is that it's a dual release circuit, so changing one changes the other.  If you want the longer release MORE with a faster fast release, then you'll have to change both on a complex switch.
Thanks for your reply Doug.
I only want to have the option to make the Release faster, so how about this plan:
With reference to the block diagram I've attached, I replace R11 with a 2M pot in series with a 1M resistor. This means that when the GR switch is on 'Single' I can go from approximately the stock Release at one end of the pot to a release time set by me through the travel of the pot. Would that work/ be a good place to start?
Sure, but I'd set the end stop as low as possible to taste, could be as low as 50K, I might guess 100-200K.
