Here's the story: so, I built this eQ last year to use as my main mastering eQ. It was my second build ever, so I'm in no way a pro at DIY.
I was successful, and EQ works... it just needs a few things to be fixed, and since I have other mastering eQs, I don't have the patience to fix it.
LO Frequency on the left side needs to be replaced. That means a 2 Pole 24 Step Rotary Switch with all the resistors.
Also needs replacing is the MF1 shape, MF2 Shape, MF3 Shape, HF Shape, and LF Shape for both channels (six 1 Pole 12 Step and two 2 Pole 12 Step) with all the corresponding resistors.
If you're interested, you can send me a song and I'll make a video where I run it through the EQ and test every feature: EQ ON and BYPASS, M/S and L/R modes, all the Gain switches, and all the FREQ switches.
I'm not a pro builder, and this was only my second build. So, this is EXTREMELY RECOMMENDED for PRO BUILDERS ONLY!!!
It cost me $1,250. I'll take $700.
EXPERIENCED BUILDERS ONLY!!!It cost me $1,250. I'll take $700.
