Baxandall Eq circuit, any comments?
weiss
Germany
I thought about building this baxandall equalizer circuit. Found it interesting that the corner frequency doesn't change with the cut/boost setting.
Any comments are welcome.
thanks
  • bax eq vari freq.pdf
Strictly, it's not a Baxandall; totally different topology.
Does it really matter? Is it actually true? What's the "corner frequency" in an EQ? Doesn't it actually depend also on the amount of Boost/Cut?
Build it and judge by yourself if it really makes a significant difference...
IMO the only difference is that it makes variable frequency easier.
Alright, i'm also not sure if it makes a difference.. anyway i searched a little more and i'm gonna build this circuit only with stepped frequency selections:
Now i ask myself, what would be the most useful op amp for this circuit?
Do you guys know what Dangerous uses in their bax?
I got these here..
NE5532
TL072
THAT 1206
LME49270
LM4562
I got these here..
NE5532
TL072
THAT 1206
LME49270
LM4562
THAT1206 is not an opamp; can't be used in this position.
All the others can be used; some may disagree, but I think you would be hard pressed to hear a difference between all the others in this configuration.
Alright thank you!
I am just gonna try and see  :)
Quick question, am i correct, for modifying the frequency i gotta change R3 and C2 ?
thank you!
Just go with LM4562 they are 1.60 at mouser, the LM 49720 seems to be the same as the 4562 but more expensive.
Thanks for the input, user 37518!
I already got a bunch of them here, that's why i asked.
weiss said:
Alright thank you!
thank you!
C1 and C2
weiss said:
Alright thank you!
thank you!
Actually, the HF corner frequency can be altered by changing either R3 and/or C2. However, there's also interaction with the values of R1, R2 and VR1. With the actual values, the HF corner frequency varies with the amount of LF boost/cut.
In order to make the shift more predictible, I would increase R3 to about 10k, and scale C2 accordingly.
oh okay! i am gonna try that. but wouldn't that be the the principle of a baxandall?
What do you mean there?
that the corner freq changes when adjusting gain? i mean, for example increasing gain from 1db to 5db, won't the freq naturally increase then?
Actually there is no set definition of the corner frequency - the usual -3dB point just doesn't work for EQ's- but it is quite possible to determine graphically a pivotal frequency, and it can be shown that it does not vary significantly with the amount of boost/cut, as long as certain constraints are observed. The math analysis is too complex for this thread.
Thanks for the comments!
Do i need to keep attention to something when wiring the Op amps? Do i need a buffer schematic?
Or can i just use this scheme:
So i wired up my first prototype of the Baxandall Active Tone Control using the NE5532 +/-15V.
I followed this schematic:
The thing is, with the potentiometers and the switched capacitors i get no change in tone.
The only difference i hear when i take them out of the circuit is that the overall loudness decreases..  ???
Would be really grateful if someone could help me out here !
thanks
Ansgar
By definition, the Baxandall tone control is always active.
Then there is something wrong with your circuit.
Well, I see you have only two wires coming from the PSU! You should have 3, one for positive voltage, one for negative and one for zero-volt ("ground")! That means the circuit is not powered correctly.
thank you guys,
the pots are not making noise or anything. i bought them new, they should be fine.
i wired the 0v connection to pos. input of the opamp (pin 3) but nothing changed.
i replaced the NE5532 with a LM4562 but no change.
There is also no difference if i disconnect power ???
