Aluminum bus(s) channel
« on: June 28, 2019, 02:30:45 AM »
Has anyone made a Neve buss channel? End view attached., this is from a broadcast series desk. Channels are about 5mm wide. The cover (hidden by ruler) is just flat stock with two screws, but is integral for shielding..  Original bars ran the length of the desk and held all the bus(s) feed resistors and strips.
« Last Edit: June 28, 2019, 02:34:36 AM by atavacron »
Re: Aluminum bus(s) channel
« Reply #1 on: June 28, 2019, 02:36:43 AM »
We’ll see if this posts.
« Reply #2 on: June 28, 2019, 02:37:32 AM »
Rear view
« Reply #3 on: June 28, 2019, 02:44:31 AM »
Front, busses labeled at right. The top one holds 10 busses and is a bit tricky to find (well, they both are). I believe pins and insulators were Cambion. The chamfer still shows up in their spec sheets; sadly the exact pins are no longer in production, but a matching PTFE insulator should be accessible.
« Last Edit: June 28, 2019, 02:47:40 AM by atavacron »
boji
« Reply #4 on: July 03, 2019, 05:25:57 PM »
Maybe do a google search on it include the groupdiy in the query, as I recall about 6 months ago someone in fact taking that route and sourcing the bushings, etc with pictures. I can't recall at the moment if it was resto or clone.
Edit: one thing I do remember is they did it like the old Neve's and used the aluminum extrusion both as a 'half shield' for resistors as well as a bus bar for summing. I don't remember seeing any copper down in the channel.
Edit2:  Ah, I found the thread!  It was a member "API" doing a resto:
https://groupdiy.com/index.php?topic=63116.msg820179#msg820179
So hardcore!  Inspires me all over again.
« Last Edit: July 03, 2019, 05:40:04 PM by boji »
« Reply #5 on: July 09, 2019, 01:55:43 AM »
That sent me on a whole ISEP tangent via SRS. Doesn’t look like they have anything close to the right extrusion but it’s nice to see all those framing resources. I couldn’t find the shot of the buss channel you might be referring to, though I recall it was a different one than what I’m after - much larger cavity, basically just U channel. This is much more akin to a modern heatsink extrusion.
Wish I knew who the OEM was! Sometimes they keep it on file...I’d like to have some knobs made and it turns out that Diamond Engineering in Sussex actually kept the original spec for the broadcast series knobs (which actually are a bit of a pain in the butt as designed due to the knob cap mounting method). Not really affordable unless you can get up to a 500 count, but interesting nonetheless.
boji
« Reply #6 on: July 14, 2019, 03:24:40 PM »
a different [busbar] than what I’m after - much larger cavity
Some of those look fairly large to me!
Since it's a section of the frame that does not require a high degree of accuracy, if it must be U-bent aluminum, go to a hardware superstore and get sliding door framing and DIY it up?
Post progress, if you don't mind!
/cheers
« Last Edit: July 14, 2019, 03:44:30 PM by boji »
cyrano
« Reply #7 on: July 14, 2019, 05:45:00 PM »
How about this one?
http://alberko.com/index.php/heatsink-extrusions/161as.html
It's a little less than half an inch between the cooling fins and about half an inch high, gives you a 20 channel bus...
Why is it people love to believe and hate to know?
« Reply #8 on: July 14, 2019, 10:54:24 PM »
How about this one?
Resourceful! I don’t think 1/2W resistors would fit though.
My application is 9 busses btw.
Last post July 19, 2004, 09:59:33 PM
by CJ
Last post January 10, 2005, 02:30:06 PM
by dale116dot7
Last post May 04, 2005, 12:44:53 PM
by pucho812
Last post June 11, 2018, 11:34:43 PM
by Enriko.66
