Potato Cakes
Re: PCBs for scalable DIY Neve style summing mixer possible feeler
« Reply #20 on: November 07, 2019, 02:33:44 AM »
So I did this sorta. Kind of a blend. API meets Neve.
Check out
https://groupdiy.com/index.php?topic=62302.0
I used 990s and app DOA's to keep in line with the 24v needed for the Neve boards I used for summing. Ian Thompson Bell (former Neve tech) pretty much walks me through everything
Where did you end up with your buss resistor values? I have been reading Ian's info for his DB25 passive summing, but it is for balanced connections whereas I will be summing unbalanced signal from the NV circuit.
I'm going to try to meet with the guy doing the board layouts next week. I just need to compile my notes before then.
Paul
Rocinante
« Reply #21 on: November 07, 2019, 11:20:34 AM »
15k I believe but let me check my notes. It might be 47k but I do remember I had to play around a bit and got help. I created a junction board to send the signals to the main, aux, metering and monitor outs that I would be happy to send you for ideas and for you to mess with. I also created a back plane to fit the API type input cards.
If there's a harder way to do this, I haven't found it yet.
Rocinante
« Reply #22 on: November 08, 2019, 02:45:11 PM »
I was off. It is either 10k or 4k7. I'd have to open it up to know which. I think 10k offered better noise but I am not 100% what I chose.
Potato Cakes
« Reply #23 on: November 08, 2019, 03:48:59 PM »
Copy that. Since this is a scalable design to be used with a summing amp of the builders choice, there will be some level of buss resistors computation that will fall on the end user. 10k is one of the values I want to try for my initial build. This is to be a DIY project, so the builder will have to know or do testing to find out what the input impedance of their summing amp is and proceed accordingly.
Paul
Potato Cakes
« Reply #24 on: November 11, 2019, 04:44:46 AM »
Tomorrow I am scheduled to meet with the PCB designer with all of my drawings and get the ball rolling on getting these boards made. Here's where I've ended up:
- VTB9045/46M or EA-10468 on board foot print with user selectable jumpers for preferred series/parallel winding configuration. You can also use these same pads to wire a mute.
- on board switch for Mono/Stereo. Can be wired off board or wired to a pan control.
- trimmers for feedback gain and attenuation, which can be wired off board for level control
- expansion input from additional boards
- sized to fit two boards (16 channels), summing amp, output transformers, and PSU in a single rack space enclosure. This will depend on size of output transformer, summing amp PCBs, and number of front panel controls used
Is anyone else interested? I do not know the price at which to sell these at this point. I can't it would be more than $50 USD but no promises.
Paul
Rocinante
« Reply #25 on: November 11, 2019, 10:07:23 PM »
Why not design them yourself or have one of us work with you?  Eagle is a great program and can be learned relatively quickly. I have the full version as i use it a lot but you can download the free version which is still very good
« Last Edit: November 11, 2019, 10:12:40 PM by Rocinante »
Potato Cakes
« Reply #26 on: November 12, 2019, 03:53:57 AM »
I did try to learn for myself a while back and I was very frustrated at the learning curve as nothing that I was doing from the tutorials seemed to translate to some of the simple circuits I wanted to make layouts. And since I'm fairly involved in a number of things I am trying to finish/accomplish, farming this part out is best. The guy I've been using is very good and boards I get from the Gerbers he generates are correct the first time. Plus, he's great to work with and I do wind up learning from him on each project, so I don't mind paying for that. For me, right now, trying to add learning how do my own PCB would be a bridge too far. Maybe someday...
Paul
Rocinante
« Reply #27 on: November 12, 2019, 12:44:08 PM »
I get that. I hardly have time to type this. I'm intrigued to see what you come up with.
Last post January 14, 2013, 08:58:00 AM
by mig27
Last post August 11, 2016, 09:33:21 PM
by charlie2012
Last post February 23, 2019, 04:48:11 AM
by nashkato
Last post November 15, 2019, 05:16:39 PM
by Potato Cakes
