sonolink
PSU mod question
« on: July 21, 2019, 07:47:25 AM »
Hello,
If I want to use only one HV terminal (HVBA) of the attached PSU, can I just delete C7, R5, HVB1 and HVB2 from the schematic?
Sono
Why sleep when you can mix?
M.P.Stavrou
JohnRoberts
Re: PSU mod question
« Reply #1 on: July 21, 2019, 09:17:07 AM »
you would have more ripple in the ps, and perhaps audible hum...
« Last Edit: July 21, 2019, 10:29:26 AM by JohnRoberts »
Visit https://circularscience.com to hear what properly "cleared" drums sound like.
moamps
« Reply #2 on: July 21, 2019, 09:59:12 AM »
I believe the schematic should be examined from right to the left.  :)
JohnRoberts
« Reply #3 on: July 21, 2019, 10:28:48 AM »
Yes... disregard my comment...
sonolink
« Reply #4 on: July 21, 2019, 12:14:11 PM »
This PSU was designed to feed 2 valves. I want it to feed only one. Is it ok to just delete C7, R5, HVB1 and HVB2 from the schematic or would there be a load problem or some kind of unbalance?
Thanks for your input :)
Sono
M.P.Stavrou
PRR
« Reply #5 on: July 21, 2019, 02:48:53 PM »
In small audio, I would normally spend the buck for more filtering, unless I was very broke.
moamps
« Reply #6 on: July 21, 2019, 02:54:05 PM »
You should post the whole schematic, sometimes the additional RC network is useful for decoupling two stages. If you really don't need it, you can delete it.
sonolink
« Reply #7 on: July 21, 2019, 06:10:53 PM »
Thanks for your reply Moamps. This is the whole schematic of the PSU.
I used it for this:
https://postimg.cc/QHFK2fjM
I'd like to use it on a similar circuit, but that has only one tube. My concern is if feeding that tube anode from only one HV terminal is ok.
Sono
M.P.Stavrou
sonolink
« Reply #8 on: July 22, 2019, 06:17:13 PM »
Pretty bump....
M.P.Stavrou
moamps
« Reply #9 on: July 23, 2019, 06:57:08 AM »
It should be ok.  My bigger concern is will this step up converter work as it should.
sonolink
« Reply #10 on: July 23, 2019, 07:19:10 AM »
Well it does with the 2 tubes circuit :)
M.P.Stavrou
Last post February 01, 2006, 05:58:22 AM
by stereokiller
Last post January 23, 2007, 09:03:01 PM
by Arrigotti
Last post March 27, 2011, 12:32:21 PM
by Biasrocks
Last post April 02, 2012, 06:44:51 PM
by gary o
