PSU mod question
sonolink
London-Madrid
Hello,
If I want to use only one HV terminal (HVBA) of the attached PSU, can I just delete C7, R5, HVB1 and HVB2 from the schematic?
Sono
This PSU was designed to feed 2 valves. I want it to feed only one. Is it ok to just delete C7, R5, HVB1 and HVB2 from the schematic or would there be a load problem or some kind of unbalance?
Thanks for your input :)
Sono
You should post the whole schematic, sometimes the additional RC network is useful for decoupling two stages. If you really don't need it, you can delete it.
Thanks for your reply Moamps. This is the whole schematic of the PSU.
I used it for this:
https://postimg.cc/QHFK2fjM
I'd like to use it on a similar circuit, but that has only one tube. My concern is if feeding that tube anode from only one HV terminal is ok.
Sono
