I have two used Triad HS-56 transformers that I'm trying to confirm whether or not all is well before attempting to repurpose.
Using a DMM, 600ohm configuration for both primary and secondaries, both measure ~60ohms across the primary.
When measuring the secondaries, one measures ~60ohms, the other ~50ohms.
I would assume I should also see about 60ohms on the secondaries of both units just like I do when measuring the primaries.
Understanding that a DMM is not 100% indicative of the condition of a transformer as a test, would a 10ohm difference (~15% discrepancy) between these two units be something to be concerned about?
Short of testing in an actual purpose built circuit, are there other tests I can apply to better understand the condition or is the 10ohm mis-match bad news before I even start?
Thanks in advance!
Greg
