Faulty TL Audio 2011 - Need help!
Soul One
Member
Hey guys,
my TLA 2011 Tube EQ is acting up - here´s what´s happening:
- When bypassed, the signal passes through the unit flawlessly.
- When the EQ is switched in, a loud buzzing noise is audible (the input signal can be heard very, very faintly). This noise is only audible when feeding the line inputs a signal. Without any input no noise is present.
It´s important to know that the tube section is only active when the EQ is switched in!
Do you guys have any idea what to look for?
What I´ve done so far (without luck unfortunately):
- Change the tubes
- Change the ribbon cables between the PCBs
- Inspect for broken solder joints
Schematics: http://www.data.soulone.de/TLA2011_Schematics.pdf
Manual: http://www.data.soulone.de/TLA2011_Manual.pdf
Sample of the buzzing noise: http://www.data.soulone.de/tla2011_buzz.mp3
Eno
Thanks for the replies guys.
The EQ is up and running again. The issues came from a cracked PCB.
