Have you looked at these?https://www.buydisplay.com/default/oled-displayI've used some of the TFT and 16x2 displays
Many thanks for all the replies. The only half decent data sheet I found gave an MTBF of 20,000 hours which I thought was rather short. Seems this is borne out in practice. Now E-paper modules do look interesting for static stuff. I guess the only issue is they need ambient light to work which may be an issue in the low light levels typically found in studios.CheersIan
RS does some OLED ones as well https://uk.rs-online.com/web/c/displays-optoelectronics/displays-industrial-monitors/oled-displays/?applied-dimensions=4294540547Not quite as cheap as BuyDisplay.com unfortunately. I'm just about to do a little timecode project with the I2C adafruit version
I've written a lot of code for I2C OLED displays, and you can really reduce the edge rate of the I2C signal and drive the display at full speed. It really minimizes the EMI problems especially if you take the time to series terminate the data and clock lines.
Started by gevermil The Lab
Started by clintrubber The Lab
Started by Svart Brewery
Started by opacheco Brewery
