IndietownRecording
- Joined
- Oct 14, 2012
- Messages
- 130
Complete Neumann TLM 67 internal assembly and body tube. This came out of a TLM 67 mic that I recently purchased.
This assembly is in perfect shape and working order. This mics capsule assembly and base piece were used as a donor for a U67 clone drop-in kit that I recently purchased.
If you own a U 87Ai, it's a simple procedure to substitute the 'Ai' internals with this assembly and avail yourself of a much more vintage sounding 'U87 family' microphone. Both the U 87Ai and the TLM 67 are fitted with the exact same K67 capsule/basket and pattern/pad switching schema. The capsule component is simply plugged into the electronics assembly. Basically the only difference between the two mics is the internal preamp and outer body cosmetics.
You can have two Neumann mics in one!
$390 shipped and PayPal'd
