First time designing a PCB - check my work?
BluegrassDan
GDIY Supporter
Elizabethton, TN
Hey guys,
This is the first PCB I've ever designed. Just curious to have my work checked.
Traces are 60 mil. 240V on B+, total heater current will never be more than 2.9A with four channels.
I am a little concerned about the clearance between the heater traces and the first anode of the bottom tube. I think perhaps you should neck the tracks in this region.
How narrow (mils) can I get away with? I thought about doing some more creative heater routing with vias if necessary.
Well it is only 150mA of current. What width are they now?
+1, but I'm no expert.  Will you have a soldermask on the proto?
Edit: Adding a via would solve the squeeze; have one of them come from the other layer.
BluegrassDan said:
All the traces are 60 mil.
For signals. 20 mil is plenty. I think you can safely neck those heater traces to 30 mil where they pass between tube pins.
Not wishing to put a spanner in the works but when I have two  like yours sharing a heaters I usually place them on the baord with the heaters facing each other. The way you can have a pair of short fat traces directly between them.
Edit: So you would just need to rotate the bottom one through 180 degrees.
