opacheco
Collins 26U1 Peak Limiter Power Transformer
« on: August 04, 2019, 12:42:16 PM »
Do someone knows what the power transformer used the Collins 26U1?
I have one without power transformer!
Thanks anticipated
Opacheco
I love the Vaccum Tubes Sound!!!
opacheco
Re: Collins 26U1 Peak Limiter Power Transformer
« Reply #1 on: August 05, 2019, 08:00:47 AM »
Any idea?
Opacheco.
mjrippe
« Reply #2 on: August 05, 2019, 10:40:24 AM »
From the manual...
opacheco
« Reply #3 on: August 06, 2019, 12:29:32 PM »
From the manual...
mjrippe,
Fantastic information!!...thanks a lot.
Do exist a specific Chicago Std. Transformer model for this Collins Psu?
opacheco.
opacheco
« Reply #4 on: August 08, 2019, 12:41:45 PM »
Any idea about the exact Chicago Transformer model?
Opacheco.
CJ
« Reply #5 on: August 08, 2019, 04:57:26 PM »
probably a custom p/n,
however, if you want to scour catalogs one page at a time,  :o
http://www.bunkerofdoom.com/xfm/
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
opacheco
« Reply #6 on: August 08, 2019, 05:30:58 PM »
CJ, that is amazing huge information!!
Let me to check them!....😉
Thanks a lot,
Opacheco
opacheco
« Reply #7 on: August 09, 2019, 03:03:44 AM »
I have dedicated some hours in order to looking for a Chicago Transformer for my 26U Collins  Compressor but look like the CJ link with Chicago transformers Manuals  don’t have a 150 v with 135 v tap plus 6.3 v, could somebody recommend one for the power transformer for this compressor?, I don’t know what the power is (watts) it  and the amps current neither!!
Thanks in advance!
Opacheco
scott2000
« Reply #8 on: August 09, 2019, 05:33:45 AM »
Looks like there is a section in the manual that has a bunch of test voltages.  Should be able to get a better picture of what this current draw looks like from these until someone chimes in.
I'm not too comfortable with understanding how doublers affect current yet so I wouldn't know what size could be used /or get by in this original supply circuit...... but it would be interesting to hear.
Good luck
opacheco
« Reply #9 on: August 10, 2019, 01:34:34 PM »
Good luck
scott200,
Right! but maybe someone with a original Collins 26U can help me readying the impress code on a real power transformer; maybe the real transformer has more information about the electric current and power printed on one of its faces!!
Opacheco
mjrippe
« Reply #10 on: August 12, 2019, 11:17:54 AM »
Photo attached from SN: 131
opacheco
« Reply #11 on: August 13, 2019, 01:49:11 PM »
mjrippe, great pic!!...thanks a lot.
I have searched the power transformer with this information but found nothing, but after of some calculator use I found that all I need is a 6.3 Vac (CT)@ 3Amps with a 135Vac @ 0.5Amps winding !!
Do someone can remember any transformer with this power capacity?...
In other hand; I am thinking I could use a 270Vac @ 0.5Amps and a DIODE BRIDGE instance to original DOUBLER VOLTAGE configuration in the PSU, but I am not sure if this work appropriately without sound quality diminished ???....Any comments will be appreciate so much!
opacheco.
« Last Edit: August 13, 2019, 02:46:03 PM by opacheco »
opacheco
« Reply #12 on: August 14, 2019, 08:48:22 PM »
Sorry but do anyone have an idea?
opacheco.
scott2000
« Reply #13 on: August 14, 2019, 09:27:19 PM »
What is the transformer you are considering?
opacheco
« Reply #14 on: August 14, 2019, 10:03:50 PM »
Scott2000,
I don’t have any transformer in mind, I am searching for one with the 6.3 CT, @ 3Amps but my doubt is the power(watts) for the high voltage winding (or the amperes(Amps) for the 135Vac.)...I have stimated 0.5 Amps for the 135 Vac but I am not absolutely sure of that!
Any comment about it will be appreciate so much.
opacheco
« Last Edit: August 14, 2019, 10:46:06 PM by opacheco »
CJ
« Reply #15 on: August 15, 2019, 12:47:24 AM »
first step is post a schematic,
photo resize>
« Last Edit: August 15, 2019, 12:57:10 AM by CJ »
opacheco
« Reply #16 on: August 15, 2019, 11:34:13 AM »
photo resize>
CJ, thanks for your response.
Here is it!
opacheco
CJ
« Reply #17 on: August 15, 2019, 02:34:15 PM »
« Reply #18 on: August 15, 2019, 02:45:03 PM »
Everything anyone needs to know is there on the manual and schematic.  Both online.
opacheco
« Reply #19 on: August 16, 2019, 02:31:00 PM »
yes of course!...here is
http://www.steampoweredradio.com/pdf/collins/manuals/collins%2026u1%20peak%20limiting%20amplifier.pdf
Please comment about of use a complete bridge diodes rectifier in this unit because the 135Vac and 6.3Vac(CT) is no comun for!...this is instance the doubler of voltage for the 135Vac!
opacheco
Last post December 08, 2005, 09:39:28 AM
by SUPERMAGOO
Last post September 28, 2007, 12:42:02 PM
by BYacey
Last post January 18, 2009, 02:10:26 PM
by gary o
Last post August 10, 2019, 08:23:01 PM
by opacheco
