samgraysound
Mesa Stiletto Deuce Low Output
« on: August 07, 2019, 02:22:17 PM »
Hi All,
I am trying to fix a Mesa Stiletto Deuce. It has low output, maxing out at 70w, when rated 100w. This is when driven from the effects return, so I'm pretty sure it's the power amp. schematic attached
Please help me troubleshoot. I have tried new power tubes. New V5. Checked tube voltages. Checked OT.
« Last Edit: August 07, 2019, 03:36:56 PM by samgraysound »
Sam Gray
Owner & Technician, Sound Audio Repair
www.soundaudiorepair.com
Recording Engineer, www.samgraysound.com
Khron
Re: Mesa Stiletto Deuce Low Output
« Reply #1 on: August 07, 2019, 08:45:43 PM »
"Driven from the effects return"... With what amplitude of signal?
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
samgraysound
« Reply #2 on: August 07, 2019, 10:36:00 PM »
Just turning the oscillator up until the amp is at max output. Haven't measured the exact input amplitude for this. I can tomorrow.
Sam Gray
radardoug
« Reply #3 on: August 08, 2019, 12:17:45 AM »
When you say maxing out, do you mean when the waveform starts to distort? A lot of guitar amps only produce rated power when producing at least 10% distortion.
samgraysound
« Reply #4 on: August 08, 2019, 12:22:00 PM »
I mean i am driving the amp into a load, monitoring AC RMS level at the load. Turning the oscillator up until the level at the load won't go up any more.
Sam Gray
CJ
« Reply #5 on: August 08, 2019, 09:19:25 PM »
what frequency?    try 500 Hz
make sure dummy load ohms = transformer tap
there appears to be a half power circuit in the cathodes, watch out for that,
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
samgraysound
« Reply #6 on: August 12, 2019, 01:05:25 PM »
I talked to Mesa.
They basically told me that the amp is probably not actually 100w and the marketing department just rounded up.
 :o
so cool.
Sam Gray
Last post August 08, 2004, 11:38:41 PM
by deanp920
Last post February 23, 2005, 02:35:48 AM
by PRR
Last post March 17, 2013, 01:23:28 PM
by 12afael
Last post February 23, 2010, 05:26:35 AM
by kambo
