Cat7 connector and audio
boji
Maryland, USA
Bought some rather cheap punchdown cat7 connectors, as I was thinking of using them in the console.
Noticed inside the housing there's a mini PCB connecting the 'V' terminals to the RJ45 pads. Traces are VERY thin. I'm going to guess they are 10mil for a total length of about 2 inches. Anything to be worried about?  Of course I'll try them out and see, but sometimes the advice I get saves me lots of time (at your expense, thank you!)
-Boji
Trying out some of the trace width calculators, Putting in a random temp of 80 degrees  it appears 10mil can handle it... forgive my ignorance on current requirements and emotional responses to thin traces.  I recall someone saying before that 10mil is okay, I just don't want thin audio too!
Why are you buying "cheap" connectors? Do you want to spend a week tracing faults, as I just did with my telephone connectors?
In a properly designed CAT5+ connector, those PCB traces will be impedance-matched and balanced so they present "no" discontinuity to many-MHz data signals; so they ought to be plenty good for audio.
And as a general thing, an inch of skinny pipe in a 10 foot run is no big deal (as I tell myself to avoid up-sizing my water filter array plumbing).
Mainly to get acquainted with male punchdown RJ45's. They are cheap relative to other 10gb rated products. I'll likely stick with quality cat6 connectors.
Thank you! I'll try a few out just to see how easy it is to use console wire over them.
