Re: DIY M50 capsule
« Reply #20 on: August 10, 2019, 12:58:05 AM »
Obviously there are solutions like this, which are very simple to try out.
However i strongly believe these spheres should not be used with hyper or cardioid mics, as it leaves an empty resonant chamber behind the capsule.
Since the holes of backplates are not sealed i can not imagine what kind of havoc it would do to FR of the mic, let alone pattern response.
bremusound
Re: DIY M50 capsule
« Reply #21 on: August 10, 2019, 11:31:33 AM »
The version i am talking about.
This capsule is also used in the KM83, KM130 and KM183.
‚Honeycomb‘ reflectors are also used in Schoeps capsules.
Re: DIY M50 capsule
« Reply #22 on: August 10, 2019, 12:31:19 PM »
Not realized yet, but I bought this:
https://www.ebay.com/itm/40mm-Diameter-Solid-Round-Acrylic-Sphere-Plexiglass-Ball-Ornament-Clear-5pcs/183144669862?epid=18002459477&_trkparms=ispr%3D1
and
thought about this:
https://www.ebay.de/itm/Oktava-MK-012-Omni-Capsule-Stereo-Pair-Silver-Brand-New-Free-Shipping/220400195022?hash=item3350e015ce:g:ovAAAOSwB0hcfEMp
I think that this would be the best price performance combination. The only thing I don't know, how much polarization voltage this capsule need.
Would be voltages from M50 schematics sufficient ?
Re: DIY M50 capsule
« Reply #23 on: August 10, 2019, 03:47:05 PM »
If it's 57v as specified in schematic, it should work just great.
As i used ST51 for this experiment 40v was a bit low, some noise issues at distance.
So i used an extra DC-DC board i had from Behringer B2 to get 60V, and it works great with my capsule.
edit:
Now that i am actually looking at the schematic for the first time, as i was going for Fet version, i see that 600pf cap anode to ground. Hm...
« Last Edit: August 10, 2019, 04:30:03 PM by kingkorg »
Re: DIY M50 capsule
« Reply #24 on: August 22, 2019, 11:48:16 AM »
40mm ball arrived today, so here's an update.
« Last Edit: August 22, 2019, 11:51:32 AM by kingkorg »
Re: DIY M50 capsule
« Reply #25 on: August 24, 2019, 10:21:49 AM »
Looks great. Where did you get it ? And sound ?
Re: DIY M50 capsule
« Reply #26 on: August 24, 2019, 11:23:55 AM »
https://s.click.aliexpress.com/e/oSIraolT9  ;D
I have no m50 to compare it to, but it measures exactly as it should, and sounds great.
As it's meant to be a far mic the circuit is afjusted for lowest noise, not highest headroom.
So the capsule is polarized at about 80v, fet rebiased for highest output. It is very low noise, in range with my Shure KSM44.
Neumann M50
Started by riggler « 1 2 3 4 5 » Drawing Board
Last post September 03, 2019, 09:02:42 PM
by rmburrow
Last post February 01, 2010, 08:58:53 AM
by bernbrue
Last post November 02, 2012, 04:50:25 PM
by riggler
Last post June 22, 2018, 01:38:03 PM
by Pip
