Old style toggle switches
mskeete
Active member
Any idea where I can buy some old school switches like these?
Thanks in advance
Mark
If you dismantle one you may find the push buttons are just slipped over the usual style slide switch , if so, its a commonly available part ,
Even the usual pattern slide switch will probably fit in any case , just make sure you have the right type of contacts , ie dual pole , change over or on off on etc .
Search term 'Slide switch'  .
I dont have the unit to hand. Took a few pictures and gave it back to the customer.
I have to design something with a similar look.
You're right, they appear to be standard slide switches with an attachment.
I've seen some used switches online but nothing new
Another example.
Would be nice to find a brand new switch with the lever already attached
