REDD EQ without the RS127
johnheath
Sweden
Hi all...
I have read through the topic of the REDD EQ with the added RS127 (Brilliance pack) and it seems just fine.
But... I am a bit interested in building the REDD EQ without the RS127 pack. This is for a small mixer project to use in rehearsal situations and it does not require a full EQ when I just need to be able too cut and boost 100Hz and 10kHz.
My question is if somebody here can advise me on how to revise the schematic compared to the one with the added RS127 pack?
https://groupdiy.com/index.php?topic=51030.0
Best regards
// John
It is not too hard. You basically strip out the mid section and replace its resistor ladders with two resistors. When I can get to my printer later today I will mark up a schematic for you.
OK, here you go; image attached.
Core of the EQ is an attenuator consisting of the 22K resistor and the 5K1 resistor giving a nominal insertion loss of 14.5dB. Bass boost is achieved by adding a series RL across the 22K and top boost is applied in the same way using an RC network. Bass cut is by series C (with parallel R) in series with input. Tip cut is achieved by a series RC across the 5K.
I have scribbled out the bits you don't need, added the 22K and 5K1 (they basically replace the mid ladder) and gone over a few lines just to make sure they are visible. Anything not clear just ask.
Many thanks to you Ian
I had calculated the 22k but it did not seem to add up in the end... the 5k1 to 0V should do the trick.
Best regards
// John
