weiss
How do you use your Neve 33609 compressor / clone?
« on: August 13, 2019, 12:46:39 PM »
I would be interested to hear your techniques of using the 33609 compressor from neve or similar clones.
Because of the combination of limiting / compression and the different time constants i find it it not as straight forward compared to my other compressors. Is there a special approach you follow? What material do you use it on? Do you omit one of the sections? Just looking for some ideas.
Thank you  :)
kambo
Re: How do you use your Neve 33609 compressor / clone?
« Reply #1 on: August 15, 2019, 01:27:59 AM »
my Igor staff are back home... but i use to get dc voltage from the power supply's adjustment/calibration out! and feed that to where ur control voltage going in... works really good, especially if u have a quiet part in the song, and kicking back in loud... so that DC voltage is setting an external threshold! measure and apply so ur compress,/limit thinks song is only dropped a bit!
Igor was so crazy surprised with it  ;D
edit: and if your diodes and transistors in specific section ( i forgot now) are not closely matched, dont even bother  building them, Igor told me!
« Last Edit: August 15, 2019, 01:41:47 AM by kambo »
weiss
« Reply #2 on: August 15, 2019, 07:05:22 AM »
Interesting trick. What does it do exactly to the signal? I was more asking about the general settings and the type of music or tracks you're using it on. My unit sounds fine as it is now..
ruairioflaherty
« Reply #3 on: August 15, 2019, 07:45:47 PM »
My Igor kit sits unbuilt, maybe someday.  But I used to rent a stunning original for mix work when I first moved to L.A.  I never got anything good out of the limiter section, but I have seen friends use it on drums with good results.
On the comp I found it excelled on the mids.  If a sound needed to be snappy, modern or had fast lows it didn't work.  But on mids like acoustic guitar, vocal etc it was glorious.
weiss
« Reply #4 on: August 16, 2019, 07:30:23 AM »
Nice! I made similar experiences. I'm not sure about the limiter section either. Still trying to figure out how it interacts with the comp section threshold-wise.
Rob Flinn
« Reply #5 on: August 18, 2019, 04:06:03 AM »
To understand the 33609 it is useful to examine the circuit diagram.    I think that the limiter takes it's sidechain from a different point than the compressor.    The limit s/c is fed from a point just before the output transformer obviously so that it is capable of preventing an overloaded signal being passed on to the next piece of gear.    The compressor s/c is taken from a point just before the BA640.  Since the gain make up seems to be done by changing resistors on the BA640 one can conclude that the gain make up won't affect the compressor but it will affect the limit. i.e the compressor takes it's sidechain BEFORE the make up amp & the limiter takes it's sidechain AFTER the make up amp.  This makes sense because the limiter is there to stop overloading the next unit down the chain, whereas the compressor is there to reduce the dynamic range or increase the average signal level.   Or at least that's what the unit is designed for rather than pummelling the living daylights out of a drum signal.
The limiter is actually really good at holding things at a level.  If you scope it on the bench & you have the unit calibrated properly you can see that if you have the thresh set at +4dB & you wind a massive signal into it (maybe +30dB) it will hold it at +4dB perfectly.     If you want to get the limiter pumping you need to crank up the make up gain and it then starts to sound funky.   Personally I don't use Neve compressors for this function because things like the TG limiter I find have a preferential sound  in this capacity.
I quite like using the compressor to even the signal level out a bit & use the limiter to keep transients in check.    This is particularly useful if you use a bit of compression when tracking like I sometimes do.
« Last Edit: August 18, 2019, 04:50:44 AM by Rob Flinn »
regards Rob
Whoops
« Reply #6 on: September 27, 2019, 08:22:53 PM »
That's a quite good question, also relevant to myself.
I have had some 33609 in different studios over the years and was never able to make it work for myself.
Unlike other compressors with this one I always prefer the bypass signal than with the 33609 on, being it on a mix or individual instruments I was never able to make it work for myself.
There are some high mids that pronounced with this unit that I never enjoyed or never really fit the program I was working on at the time.
weiss
« Reply #7 on: September 28, 2019, 06:17:52 PM »
Interesting, which style/instruments did you try it on? I find myself tweaking a lot as well.
Sounds rather discouraging for such a well-known piece of equipment.
Whoops
« Reply #8 on: September 28, 2019, 10:16:32 PM »
from what I can remember...
Mixes: pop, rock, acoustic
instruments: Drums, Piano, vocals, Stereo Backing Vocals
never worked for me and other compressors always work, but maybe it's my problem
dmp
« Reply #9 on: November 12, 2019, 04:46:32 PM »
I built Igor's 33609 and it is a really nice sounding piece. I agree it's great on acoustic guitar.  I just use the compressor - haven't used the limited much on anything.
I have been thinking of adding a HPF to the sidechain signal, for using on a drum bus.
I've been doing heavy compression in parallel on stuff -using compressors as effects more than mixing.
fazer
« Reply #10 on: November 13, 2019, 04:30:06 PM »
Is that in real Neve 33609s?  I used one on a NPR music show for 6 years.  Mostly acoustic instruments and the real neve had a great glue as well as a sheen up high.   The real transformers are beautiful sounding to me.   I wanted to clone but got cold feet about how well it would match up.   I never did the parallel compressor on drums back then but I know engineers that would patch them into the effects send and return and put that on snare and kick and vocals like adding reverb.   I would love a clone if it sounded like the original.  Mostly for lightly touching the main mix with that sheen.
Last post April 28, 2005, 05:59:09 PM
by Kev
Last post June 30, 2005, 01:43:05 PM
by Greg
Last post October 26, 2007, 02:58:51 AM
by Ilya
Last post February 14, 2020, 09:07:50 AM
by weiss
