iSK Little Gem internals
« on: August 13, 2019, 04:43:02 PM »
I recently got myself a pair of iSK Little Gems, so I thought I'd take a picture of the internals and upload it. The input capacitor and all other components are through hole, and the transistors appear to be 2N5401s. The PCB is a bit cramped, so I'm not sure what mods could be done to it. It's worth noting IMO that you'll probably have to clean the back of the PCB because there was quite a bit of leftover flux.
The capsules have the slotted grilles like a lot of the Chinese ones, and they also have a layer of foam, so there may be another grille under the foam.
Another interesting thing is the contact pin in the body retracts quite a bit.
Again, I'm using my phone's camera, and it's not great in normal home lighting.
« Last Edit: August 13, 2019, 07:05:38 PM by Icantthinkofaname »
Khron
Re: iSK Little Gem internals
« Reply #1 on: August 13, 2019, 05:05:38 PM »
JFET's something like the ones in BM800's and such, 2SK596 or something?
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
« Reply #2 on: August 13, 2019, 05:12:09 PM »
How much would that reduce self noise if at all? The mics have an advertised 24 dBA but the noise is actually pretty usable IMO, and I don't know how much comes from the capsule.
Think there's space to add a capacitor for high frequency roll off? Ideally I'd only want about 3-4db attenuated so it doesn't mess with the omni capsule too much if it's actually flat like they say (which I doubt). High end rise starts after 5k on cardioid, after 4k on super cardioid.
« Last Edit: August 13, 2019, 05:15:19 PM by Icantthinkofaname »
« Reply #3 on: August 13, 2019, 06:13:26 PM »
You can do the typical Schoeps EQ thing, for me that made the mic too dark. YMMV.
http://www.audioimprov.com/AudioImprov/Mics/Entries/2014/2/8_EQ_Pt.3_-_Transformerless_Mics.html
« Reply #4 on: August 13, 2019, 07:01:42 PM »
Thanks for the link. I'm a bit unsure about doing it just because I don't want it to be too dark.
For "professional" use I'm planning to order a couple new MK-012 hyper cardioid caps, but I'd like try to mod the Little Gems as well to see if I can make them sound just a bit better. I could probably just EQ them in post as well because I'd still like a bit of the high end emphasis to remain.
« Reply #5 on: August 13, 2019, 07:34:54 PM »
You just trim the 500k timer to your liking. The pot adjusts attenuation level. Or use lower value capacitor for roll off to start at  higher frequencies.
Gus
« Reply #6 on: August 13, 2019, 09:21:47 PM »
I don't see a DC to DC converter section.
Is there anything on the other side of the PCB?
Are the capsules electrets?
« Last Edit: August 13, 2019, 09:25:13 PM by Gus »
Re: iSK Little Gem internals New
« Reply #7 on: August 13, 2019, 11:15:48 PM »
Nothing on the other side, the capsules are electret. The iSK Pearl is also electret but it's quite a bit flatter sounding. Prefer it's sound to other cheap SDCs like the Rode NT5. Unfortunately the Little Gem capsules (at least the cardioid and super cardioid) aren't very neutral, but they were only $50/pc with the capsules.
« Last Edit: August 14, 2019, 04:23:50 AM by Icantthinkofaname »
Last post August 07, 2013, 07:39:30 PM
by HellfireStudios
Last post December 18, 2018, 11:25:40 AM
Last post June 10, 2018, 04:16:39 AM
Last post May 10, 2019, 12:27:44 PM
by camarada78
