It has long been an ambition of mine to design an affordable tube mixer. I have been working on this recently and I think I have come up with something that people might find interesting. I have tried as far as possible to cut out everything unnecessary and you use standard parts wherever possible. Even so you can pare down the cost even more by omitting some transformers or even whole functional areas. It uses 14 tubes, fits in an off the shelf box and the total parts cost should be about $2200 for the full set of options. For this you get:
4 mic pres with transformer balanced inputs, HPF, echo and foldback sends, pan and rotary fader plus unbalanced insert or direct out
16 input passive mixer (2 x 25way D ) with tube gain make up and rotary fader
2 transformer balanced direct inputs one each to the left and right buses (for expansion)
Echo send master, foldback send master both transformer balanced
Bus master with two channels of REDD PLUS passive EQ, master fader and transformer balanced outputs
2 transformer balanced FX returns
PFL on all mic channels (mono), passive mixer (stereo PFL) and FX returns (mono)
Monitor section with two VU meters, transformer balanced monitor out, monitor level, PFL over ride and 2TK playback input
External power supply
I would make all the PCBs available at cost in the Black Market
What do you think?
