Hey Ian, thanks for your reply.
I am building a D-AOC as my first tube project. I've been at it for a while and the compressor is basically ready for first fire-up very soon.
Many people over in the D-AOC thread is noting that that the compressor needs to be driven at quite high levels to compress, altough using higher ratio input transformers and back to back vactrols lower the threshold. I am using lundahl 1540's on the input in a 1:1 ratio so I think I might benefit from some gain on the inputs, and rather use the input controls on the d-aoc for calibration of the stereo signals. So I've been tinkering with the idea of adding a TLA to the input of the compressor and am curious as to how feasable the idea is.
I don't know if you're familiar with the D-AOC design, here's the schems:
http://www.silentarts.de/DIY/D-AOC/D-AOC_Schematic.pdfand board overlay:
http://www.silentarts.de/DIY//D-AOC/D-AOC_PCB-Overlay.pdfMy power transformer has 250V (0.1A) + 9V (2.5A) + 24V (0.5A) secondaries. I'm not sure of the current draw of the circuit, and am wondering if the transformer has enough B+ and Heater current to drive the additional TLA with the D-AOC psu (as you state in your documents this should be no more than another 15mA B+ or thereabouts configured as a line driver?). The B+ PSU form the D-AOC is the same as the GYRAF HT supply, don't know if you're familiar.
I see the TLA wants an elevated heater and minimum 250V B+. Here's some voltages from a working D-AOC:
https://groupdiy.com/index.php?topic=26585.msg330048#msg330048Could I take the B+ from say before R128 and use it for the TLA? I presume that this is a little over 250V. For the elevated heaters, could I make a circuit as in your HT250 schematic, with a voltage divider from the B+ (again from the same place, just before r128) using 2x33k 2w(in paralell? r4 in HT250 schems) to a 22k 2W (r5 in HT250) with a 100uf cap (C5 in HT250) from the elevated heater to ground. I see this voltage divider also is used as a bleed resistor for the B+ when the unit is turned off, wondering if this will eat too much current for the power transformer, if there are other resistors in the D-AOC that acts as bleed resistors?
Could I use the lundahl 1540's directly to the TLA, and go unbalanced from the TLA to the D-AOC?
Lots of questions, I hope I don't derail the thread but I've beenr reading up on all your wonderful documentation and got curious.
Thanks for any input and all the best,
Magnus
