As promised a pic of the completed power supply:
and its rear panel courtesy of Schaeffer:
BluegrassDan said:Looks good, Ian. I like those cases for external PSUs.
They made one from scratch. Modushop provide dxf files of their cases so it is easy to draw up a panel.BluegrassDan said:Did you send the panel to Schaeffer, or did they just make a new one to specs?
fragletrollet said:Beautiful Ian, I hope I one day can build a small tube mixer for my studio.
Quick question (might be answered somewhere else, sorry if so): what ht voltage does the TLA expect? I am playing with the idea of adding one of these boards on the input side of the DAOC I'm building to use it for input gain (so I can use trimmers in place of the pot meters in the compressor circuit to accurately match gain between channels) and was wondering if I could use the transformer I'm using (250ac secondaries + 9v for the heaters)
scott2000 said:Thanks Ian...Is the drawing correct? I'm having a difficult time following it. Just want to make sure...
ruffrecords said:I now have the three main components; front panel, main board and rear panel, set up on the bench ready to start wiring it all together.
I made all the spare protoype main PCBs available here at cost. I have one left if you are interestedAleguitarpro said:Very interesting project.
Following with attention.
Have you got any board available (maybe spare prototypes)?
There are lots of transformer options. I suspect the transformers will be the parts most often changed by constructors.To keep costs down what are output transformers options?
I see in other of your projects you suggested Edcor or Carnhill.
But I can't recognise this particular output transformers in photo.
I checked all the thread but maybe I missed something.
I found OEP a very good option as input transformers.
Perform well together with other expensive options.
