JAY X
Rivet nut versus caged nut
« on: August 25, 2019, 11:20:50 AM »
Hi!
Can a caged nut resist tensions or forces the same way as a Riveted nut?
I ask this, because i am considering using caged nuts instead of riveted nuts for frontal/side panel mounting for the 1u/ half rackmetal boxes i am designing.
Maybe It is a bad idea, but i want to have opinions on this.
Thanks a lot!
Jay x
JAY X
Re: Rivet nut versus caged nut
« Reply #1 on: August 29, 2019, 03:44:02 AM »
After a bit of search i found this link.:
https://www.canford.co.uk/CANFORD-RACKPANEL-HALF-RACK-WIDTH-Blank-rack-panels
It seems a good solution to use caged nuts to hold 2  half rack front panels.. instead of machined aluminum pieces like the RND half rack blank panel. So i will continue  from here..
Jay x
abbey road d enfer
« Reply #2 on: August 29, 2019, 10:58:23 AM »
Caged nuts are more robust than riveted nuts, and they can be replaced if the thread is damaged. They take more space, though.
Last post May 12, 2013, 07:35:09 AM
by helterbelter
Last post June 26, 2018, 11:27:58 AM
by hasbeen
Last post March 01, 2019, 05:25:21 AM
by Potato Cakes
Last post October 14, 2019, 09:59:19 AM
by Jeff Goodman2
