Newmarket
Re: Questionable Article on Impedance
« Reply #40 on: September 11, 2019, 08:05:48 AM »
I am surprised that these days all new guitars are not Bluetooth enabled.
Yeah - but then there'll be vintage / relic'd Bluetooth  Or 'Valve' Bluetooth... ::)
« Reply #41 on: September 11, 2019, 11:59:08 AM »
The absolute minimum is 15 msec. Most stuff is around 35 msec.
You would think with processors running in the GHz region it would be a lot shorter than this. Just shows how poor real time software is when written in a high level language. Some things never change
cyrano
« Reply #42 on: September 11, 2019, 01:13:15 PM »
I don't know about BT, but with Wifi, there's a lot going on because it's wireless. That brings encryption, channel hopping, changing of authentication, retransmits for robustness...
That's why low-latecy audio over wired ethernet is relatively simple. None of that stuff.
Why is it people love to believe and hate to know?
PRR
« Reply #43 on: September 11, 2019, 01:40:44 PM »
"New guitars".... but while my 2001 Honda is "old" for a car, a 2001 guitar is "newish", and ones from the 1950s are treasured. So we still need to know "impedance" on guitar interfaces.
« Reply #44 on: September 11, 2019, 04:21:28 PM »
I guess the big problem with any digital packet based system is you have to create a packet, send it, receive, decode it, buffer it and turn it into a continuous stream.
I'll stick to analogue thanks.
ian
« Reply #45 on: September 12, 2019, 01:23:28 AM »
The anti aliasing / anti imaging filters have a "long" delay all by themselves, enough to make the monitors sound funny when the live signal phases with the foldback signal delayed by a converter loop. This makes using a gorgeous $15K condenser mike for vocals less of a fun experience for the talent, who gets to hear the sum of bleed from their mouth to their ears mixed with the delayed signal from the mike through a converter loop. Sure - the HF phasing is only in the monitors, but the talent is using that to perform, and not hearing what is actually going to "tape".
For the highest quality monitoring during overdubs, routing a signal through converters is not the best idea - a simple analog split to an analog monitor mixer ahead of the converter is a much better idea.
abbey road d enfer
« Reply #46 on: September 12, 2019, 02:04:20 AM »
That's already the case with a basic analog loop, where the delay from mouth to mic is different than the delay from mouth to ear via internal conduction.  We all know that the perceived sound changes when flipping polarity.  So, what the talent hears is not the sound of a "gorgeous $15K condenser mike ", it's already "phasing". Only the guy in the control room hears it.
The additional delay from conversion becomes a nuisance when it impairs articulation; that seems to appear when the round-up delay exceeds 6-10ms.  Different people have different threshods. Practiced studio performers are competent at anticipating delay, some are not. Many singers can't make the difference between a condenser and a dynamic when monitoring on headphones.
Who's right or wrong is irrelevant. What matters is what's right or wrong.
Star ground is for electricians.
CJ
« Reply #47 on: September 12, 2019, 04:44:28 AM »
just pick ahead of the beat . i am sure Guitar Slim made adjustments when he walked to the sidewalk with that 100 foot cord to meet the pizza guy,
If I can't fix it, I can fix it so nobody else can!
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
« Reply #48 on: September 12, 2019, 11:47:45 AM »
Surely the ears/brain are used to delays - it is part of how we perceive the acoustic
« Reply #49 on: September 13, 2019, 01:36:55 PM »
I did try a Philips bluetooth audio reciever years ago just to satisfy myself it was garbage , they had the neck to badge  it 'hifi', distortion was clearly audible,  I never even got around to any kind of latency test ,back in the box and back to the shop with it .
Last post November 18, 2004, 03:41:31 PM
by
Last post November 28, 2005, 02:35:42 AM
by PRR
Last post January 01, 2010, 06:32:31 PM
by hop.sing
Last post September 11, 2011, 11:31:28 AM
by JohnRoberts
