TS-990 // Twin Servo Mic Preamp for 500 series
elskardio
Montreal - Canada
Hi Guys,
I just wanted to share my latest project. It's my take on the Jensen Twin Servo for the 500 series format.
I'm using Cinemag transformers at the Input & Output.
The discrete opamps are my version of the 990.
So far this is my favourite mic preamp. A lot of clean gain and well balanced over the frequency range.
Gabriel
I finally assembled the latest revision with the 10dB output Trim. Huge Jensen on the output. Lots of clean gain 8)
Update November 4:
Here's the latest revision with bias adjustment for the discrete opamps and pcb footprint for Jensen transformers.
Wordsushi said:
Yeah, that looks pretty amazing. Any thoughts on kits/pricing as of yet? I'm super intrigued.
I'm not planning to sell kits at the moment... But if there's enough interest I could probably do a small batch  ;)
Looks great.
At one point i did had a couple of prototypes done but never made it past there... I love their 3d type of sound.
Good luck
3nity said:
Looks great.
Good luck
Thanks 3nity
The grounding scheme  is a bit tricky with this one... I made 3 prototypes before everything was 100% stable, even at extreme gain settings.
I just ordered the final PCB revision. I added Bias adjustments for the discrete opamps to help the servo work faster. I also added footprint for Jensen transformers.
I'll post pictures when it's assembled in 1-2 weeks.
I might do a small batch of kits by the end of the year...
I have the latest revision in intensive test at 2 different studios. So far everyone's loving them.  8)
I'm also testing different flavour of discrete opamps
This is a beautiful build. I’d love to build a pair. Even if you don’t do a “kit”, I’d be interested in the PCBs
I'm still very interested in a kit.
Have you tried a version of the OA10 op amp? I just put a pair of Gary Bennett's new OA10's in a Hairball Lola and they really sound great. Adds a wee bit of bite that the Hardy 990s don't have. So, as such I have a pair of Hardy 990c's sitting around just waiting for a preamp to be put into...
Hi guys,
I updated the first post pictures. This is the latest revision with bias adjustments for the discrete opamps and pcb footprint for Jensen transformers.
I could probably make a few partial kits available before Christmas.
If you're interested, please post the following details:
- Your username
- How many kits?
- Planning to use the CA-990? or another DOA?
- Would you like to have transformers included in the kit?
elskardio said:
Hi guys,
- Your username
- How many kits?
Ricardus
I would be interested in 2 kits after Xmas. Money will be too tight before Xmas.
I would probably use a different Op-Amp, but would want transformers.
elskardio said:
Hi guys,
- Your username
- How many kits?
Fuzz Face
2 kits
CA-990
Transformers yes
