Wordsushi
Wordsushi
One kit
I have a spare pair of Hardy 990c's I'd use
Yes on Transformers/Cinemags
One kit
OneRoomStudios said:Which Cinemag input transformer are you using? Also, do you have a sense of the cost per kit? Thanks!
Fuzz Face said:I see you’ve built them with Cinemag and Jensen now. I imagine you have had more time with the Cinemag build but do you have any thoughts on differences? I guess they’re both relatively “clean”?
elskardio said:The sonic difference between both choice of transformers is very subtle... a lot of audio engineers couldn't tell them apart... but here's my thoughts:
Jensen:
- A tad more Precise in the mid frequencies
- More neutral, true to the source
Cinemag:
- Slightly more coloured
- A little lift in the low-end frequencies
Vac11 said:What voltage is feeding the 990 DOAs? +-24V as on geniue Jensen schematic? Or +-16V (500 series srandard)?
Wordsushi said:Just curious. What is the biasing procedure for different op amps?
SKJGProject said:Too bad i thought you were saving the jensen kits for people who posted....
