I've measured one audio device with a simple LM317 linear regulator and here's what I'm getting (see the attached pic). The input to the regulator (blue trace) is ~76mV RMS, while output is ~10mV RMS. Am I reading the figures correctly? According to the datasheed LM317 should provide 60-80 dB ripple reduction, so the output ripple should be in the sub mV range.
If these datasheet figures are correct, what can be causing this highish ripple?
The ADJ pin of the regulator is bypassed with the cap.
EDIT: the scope BW is 20 MHz
