Seeing as I had an open secondary winding I decided to have a look inside the casing ,
What I found is a bobbin composed of three concentric cylinders made of chemically hardened rubber, its held up remarkable well for something approaching 100 years old , Primary next to the core and outermost , secondary in the middle .Outermost primary winding is divided into three spaced sections side by side .
The unique thing about the bobbin structure is once I get the lams out and desolder the hook up wires it comes apart into 1/2 primary ,secondary and other half primary ,so I can rewind only the secondary section that needs attention without having to demolish all the other sections in the process , thats quite a neat feature .
a quick preliminary measure of the primary inductance with the LCR showed in the region of 110 hy at 100hz but drive is only a couple of hundred millivolts .
