UTC H-9986 values?
Zebra_PD
Umea, Sweden
Hi!
Got a couple of mystery UTC irons for cheap when I bought some other parts from a seller on ebay. Played less then 5$ each.
Trying to figure out the specs of these but get a bit confused looking at the specs written on them. Perhaps someone can help me out and/or guide me through how to measure them.
My best guess is that they are 1:1 600:600 ohms but that part with the splits and +9 DPM makes me wonder if they might have another ratio?
Two primary coils ,tabs 2&3 should be joined for 600ohm ,1+3 ,2+4 for step up
Center tapped secondary , 100-3500(HZ) relates to working frequency  ,
+9dbm is max level .
If you have an audio interface with balanced in and out you could hook the transformer in and see how it looks in a program like REW .
Pair of 250Ω resistors in series to the primary side taps and a 620Ω resistor across the output taps will show you what it actually does in a true 600Ω environment, at least close enough.  Compare to modern bridging response with 50-200Ω source drive and 10KΩ load to see the range of environmental effects.
Thx for the reply and the tip on REW software and a interface! Guess using that software I could make out the ratio?
So you guys think it could be wired as an step up transformer?
In that case perhaps could it be used in a PM670 build as an input iron?
