saint gillis
Hello, I'm interested in understanding how to make a popless bypass switch.
Apparently a micro-controller is often used.
Here the man explains his whole method : https://www.coda-effects.com/2016/08/relay-bypass-with-anti-pop-system.html
Other circuits are available for sale :
https://www.muzique.com/schem/bypass.htm
http://www.griffineffects.com/home/69-silent-step-true-bypass.html
https://www.modestmikesmods.com/silent-step-true-bypass
https://pettyjohnelectronics.com/shop/quite-bypass-switch/
http://labo-k-effects.com/en/index_mod_en.html
Sometimes they use a PIC sometimes an AT TINY chip, most of them seem to only use a micro-controller and a relay, whereas the first man uses an additional solid state relay.
Does anyone knows more about the principles used to make a silent switch ?
