Hi guys, have an Alesis RA150 here. It has phono and jack inputs and I would like to use both inputs at the same time but the manual states
"Only one input jack of a channel should be used at a time: don't use the 1/4"/XLR input jack and phono input jack simultaneously. Do not plug two different sources into the same amplifier channel. While this will not harm the amplifier, the sources may interfere with each other causing distortion."
I'm thinking if I just replace R107 with something like a 1k I should be good, can someone confirm please. Thanks
