Combining the power and versatility of APx500 measurement software with 3rd part
lsburden
Member
https://www.ap.com/analyzers-accessories/apx500-flex/?gclid=EAIaIQobChMI0cbg2MvG5QIVh4bACh3grwwNEAAYASAAEgJvZPD_BwE
The APx500 Flex audio analyzer is available now, with the two-channel base configuration retailing for US $3,000.
https://www.prnewswire.com/news-releases/flexibility-redefined-the-apx500-flex-audio-analyzer-300928515.html
I had recently noticed AP were now offering software that also worked with 3rd party Asio based soundcards ,
Hmmm so the 3K base package includes a mini usb based audio  interface then .
How does the licenceing  work on older hardware based systems from AP , if you aquire one second hand does the licence automatically transfer ,  Or will you be faced with bills to update /use it?
I was not under the impression that AP included an interface at all.
Software licensing is controlled with a "flex key". I don't know if that is physical dongle or a file.
I'm pretty sure this is just software with options.
For 3K you get a very very basic two channel package:
APx500 Flex - Two Channel Configuration
The APx500 Flex 2-channel basic configuration includes sequence mode, input signal monitors, file analysis, 2-channel ASIO interface support and Flex Pack 1: Level & Gain, THD+N, Loudspeaker Production Test, Stepped Frequency Sweep, Pass/Fail, and Signal Acquisition measurements...
Includes APx500 Flex Key, software, and getting started guide. (Laptop not included.)
