XLR(m) to XLR(f) Bleeder Resistor
« on: November 05, 2019, 10:49:20 AM »
Hello
I need to protect IC gear down the line of a tube compressor.  The 100 CM from Rapco Horizon is expensive.
As I have xlr barrels I’m planning just to do it myself.
Where to solder the 100K resistor?
Pin 2 to Pin 1?
This will change the output impedance?
Pro and Cons?
Thanks for advice.
Khron
Re: XLR(m) to XLR(f) Bleeder Resistor
« Reply #1 on: November 05, 2019, 12:08:06 PM »
What exactly are you trying to achieve, and why / how?
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
pucho812
« Reply #2 on: November 05, 2019, 01:34:42 PM »
I am not sure what he is asking other then he wants to connect 2 pieces of gear together, one has IC chips and one is a tube compressor.  Looks like he is planning to use 100CM rapco if that is even a part number? or he is using 100CM (around 3 feet)of length of cable.  Either way he will be fine if he just wires up a cable between then gear and is done unless there is a puzzle piece missing.
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
RuudNL
« Reply #3 on: November 05, 2019, 01:49:53 PM »
As long as the tube equipment has a transformer (balanced) output, I don't see a problem when connecting this output to semiconductor (IC) equipment.
But when the tube equipment has an unbalanced output (capacitor from plate or cathode to the output) I can imagine that you are a bit worried.
In the last case you should first get an idea of the maximum output level of the tube device.
I could imagine that two zeners in series (with reverse polarity) would short out most unwanted high voltages.
In general, IC equipment will survive a voltage of + or - 15 Volts on the input.
There is a solution for every problem!
http://www.vansteenisaudio.nl
« Reply #4 on: November 05, 2019, 01:52:02 PM »
« Reply #5 on: November 05, 2019, 01:58:03 PM »
Yes it has balanced outputs, but without bleeding resistor at the output tranny.
Will the zeners do not affect sound or impedance?
Any idea what value would work?
RuudNL
« Reply #6 on: November 05, 2019, 02:10:31 PM »
If there is an output transformer, there are no zeners or resistors needed IMHO...
pucho812
« Reply #7 on: November 05, 2019, 03:24:52 PM »
o.k. I got it....
that d-box you link is a DMX terminator and under DMX terminators.
It's for DMX applications.
"DMX is a lighting control protocol which allows users to have ultimate control over their lighting needs. ... DMX originated as a way to set the bar for lighting manufacturers to build fixtures that would all be compatible with each other, instead of having individual control stations for each set of lighting"
DMX cables can come terminated with 3 pin xlr's...
Now what two boxes do you wish to connect together.  if both are pro audio manufactured boxes, you will be fine without any special things.
« Reply #8 on: November 05, 2019, 03:34:04 PM »
Thank you RuudNL. I heard that it would.  If I want to do what rapcohorizon do, where is located the 100K resistor? Pin 2 to Pin 1?
« Reply #9 on: November 05, 2019, 03:39:44 PM »
o.k. I got it....
Thank you for commenting, Pucho!
This:
"In certain instances, equipment using “retro” and “vintage” design topologies may damage DC-coupled input stages, like those used by Dangerous Music and other high-end pro audio manufacturers. This occurs specifically when the manufacturer does not modernize the output stage to be compatible with the transistor/IC world of today."
I just want to know if the solution of 100K resistor will work. I have a mastering vintage tube compressor and I am worried. Otherwise I will have to adapt a 5W bleeding resistor at the B+ to ground (ohm law willing).
« Reply #10 on: November 05, 2019, 03:50:37 PM »
This:
This sounds like marketing speak to me. Who exactly said this?
« Reply #11 on: November 05, 2019, 04:05:09 PM »
moamps
« Reply #12 on: November 05, 2019, 06:05:23 PM »
You can use here two resistors, from pins 2 and 3 to pin 1. They are used just for discharging a static voltage on secondary vs. ground.
@pucho812
DMX termination is 120ohms  between  pins 2 and 3.
pucho812
« Reply #13 on: November 05, 2019, 07:26:38 PM »
@pucho812
yes o˚. but the rapco device he pointed to is listed under a DMX terminator on their website.   which I was just pointing out that might not be what he wants.
as wouldn't worry about it until it's a problem
RuudNL
« Reply #14 on: November 06, 2019, 03:21:38 AM »
Of course you can do anything you want.
But it is not needed and it won't cause any problems...
« Reply #15 on: November 06, 2019, 04:37:20 AM »
https://www.gearslutz.com/board/high-end/1021142-shadow-hills-mc-dangerous-gear-killer.html
Gearslutz is not exactly renowned for accuracy. I notice the guy from dangerous is reported as saying:
I
f any of your outboard that you wish to connect to Liaison has a
“floating output,” a qualified tech. can add what are referred to as
“bleeder resistors” to the transformer outputs. Parts cost about 15-
cents!
Must be a very poor design if it cannot cope with a floating output.
This is very strange because at the dangerous web site they say:
Audiophile-grade components are used throughout the LIAISON’s 100% passive analog relay switching system,
Which is by definition floating.
[silent:arts]
« Reply #16 on: November 06, 2019, 05:54:45 AM »
Cool. All my gear can be claimed as potential dangerous gear killer  ;D
« Reply #17 on: November 06, 2019, 07:10:44 AM »
Good idea. I think I will add a notice to all my tube mixers to to say "Do not use with gear made by Dangerous due to their inability to cope with professional standard signals"
RuudNL
« Reply #18 on: November 06, 2019, 04:10:46 PM »
 ;D
abbey road d enfer
« Reply #19 on: November 06, 2019, 06:18:50 PM »
Let's be frank: this is pure marketing BS. If a piece of gear leaks current, it is defective, and as such should be fixed before being put in service. Installing 100k resistors is NOT a substitute for recapping.
I hate people who exploit the credulity of the public.
Did you check if it's leaking? If not you don't have to worry, if yes, fix it.
That won't help a potential leakage issue in any way. Who suggested that stupidity?
Last post October 29, 2014, 07:49:37 AM
by mitsos
Last post November 30, 2004, 04:40:46 PM
by mathtracks
Last post July 26, 2006, 11:16:04 AM
by peeceebee
Last post March 04, 2010, 11:50:25 AM
by shabtek
