bazmcc
API 1608ii remote talkback
« on: November 06, 2019, 11:59:35 AM »
Hey all, looking for advice on rigging up a remote talkback button for an API 1608ii console.
I see the console has a 5-pin XLR talkback remote port, but I can't find existing systems to plug into here, barring the Q2 system, which I'd rather avoid.
Ideally, I'd love to have a metal box, with a button or more likely a footswitch, hardwired to the console.
Is it as simple as rigging up a box with a button/footswitch that, when pressed, makes a connection between pins 3 & 5, firing the relay to engage the console TB mic? Pin 1 could be used for an LED too
« Last Edit: November 06, 2019, 01:04:58 PM by bazmcc »
Re: API 1608ii remote talkback
« Reply #1 on: November 06, 2019, 01:04:16 PM »
Hello
According to user manual the 5pin XLR only duplicate main remote buttons, no mic input at this connector.
Pin 1 = +5 volts (fused)
Pin 2 = T/B BUS
Pin 3 = T/B ALL
Pin 4 = T/B AUX
Pin 5 = Ground
so depending at what output you want to talk, respectively short pin 2, 3 or 4 to ground (5)
I assume 5V is present to light the push buttons (if you use some with bulb or LED)
Best
Zam
bazmcc
« Reply #2 on: November 06, 2019, 01:18:22 PM »
Yeah, I initially had it wrong but had just edited my initial post! Only really need "all" talkback option, so short pin 3 to pin 5.
Thanks for the help!
Last post April 08, 2005, 05:53:09 PM
by Kev
Last post August 11, 2016, 06:07:44 AM
by Janzoulou
Last post September 03, 2009, 12:29:31 AM
by Sarcastic Sound
Last post May 01, 2019, 10:48:48 AM
by elskardio
