pucho812
quantum ground lifter
« on: November 07, 2019, 12:32:25 PM »
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
Re: quantum ground lifter
« Reply #1 on: November 07, 2019, 01:14:59 PM »
Hello
This kind of product should be prohibited...
One can die if the equipment have a fault
It's a shame >:(
Best
Zam
cyrano
« Reply #2 on: November 07, 2019, 02:11:38 PM »
As stated, they don't lift the ground.
It's just an adapter. Nothing in there. Of course, it's been "quantum" treated. Something involving a million volts...  ;)
Why is it people love to believe and hate to know?
pucho812
« Reply #3 on: November 07, 2019, 02:33:40 PM »
As stated in their title "quantum ground lifter" but no matter must be lower current otherwise they would melt the plastic.  ;)
« Last Edit: November 07, 2019, 05:18:58 PM by pucho812 »
« Reply #4 on: November 07, 2019, 05:14:24 PM »
are you kinding ???
joke start-
your right, it's worst, this lift safety earth...   ;D
-joke end
Best
Zam
Ricardus
« Reply #5 on: November 07, 2019, 07:30:34 PM »
Seems legit.
Audio mastering for hire..
Seeker
« Reply #6 on: November 07, 2019, 09:42:44 PM »
I live in a house where some of the wiring is still two prong, so I have a bunch of these lying around, so what part do I run the 1,000,000 volts through to quantumize mine?  The ground that doesn’t connect to anything?   ;D
I got a bi polar Tesla coil, I’ll try that  8)
"Sometimes you have to play a long time to be able to play like yourself.” - Miles
PRR
« Reply #7 on: November 07, 2019, 10:10:14 PM »
Lithium can help.
boji
« Reply #8 on: November 07, 2019, 10:18:01 PM »
 Someone better call Mr. Steiger!   ;D
« Reply #9 on: November 08, 2019, 03:20:18 AM »
Before you use a quantum ground lifter, surely you need to have a quantum ground?
Speedskater
« Reply #10 on: November 08, 2019, 06:04:04 PM »
Those devices if used as specified by UL/NEC rules with the mounting screw attached, won't lift the Safety Ground.
Kevin
pucho812
« Reply #11 on: November 08, 2019, 07:13:40 PM »
yes but who actually uses them correctly? most do not.  ;)
Brian Roth
« Reply #12 on: November 08, 2019, 07:30:41 PM »
Many/most? 2-prong receptacles installed in the USA decades ago have NO Safety Ground connection....just Hot and Neutral wires.  So, the screw on the outlet cover connects to.......nothing!
Bri
Brian Roth Technical Services
Salina Kansas, home of the best vinyl on the planet!
http://www.BrianRoth.com
recordingservicesandsupply.com/
www.qualityrecordpressings.com/
store.acousticsounds.com
JohnRoberts
« Reply #13 on: November 09, 2019, 02:20:08 PM »
Bri
I recall helping my older brothers do some house wiring back in the 50s. We used metal jacketed BX and not only was the metal jacket secured to the metal junction box by a metal screw clamp, but I was taught to wrap the bare ground drain wire around a clamp screw to secure it for even more robust safety ground bond.
Back then plastic jacketed romex was still new but even it had 3 wires, at least the stuff my brothers bought.
My current house built cheaply  (probably in the 50s) is all two wire with no safety grounds to be found. (I had to DIY my own safety ground wire for my kitchen outlet next to a sink)
The good news is that the GFCI outlets like I have installed everywhere near shock hazards will work fine without grounds.
Don't only half-ass tune your drums. Visit https://circularscience.com to hear what properly "cleared" drums sound like.
Matador
« Reply #14 on: November 09, 2019, 02:34:54 PM »
Quantum grounds are very tricky: they are both safety earth bonded and simultaneously not safety earth bonded.
Once you open the chassis and observe the ground, then it will actually be bonded or not.  So long as the chassis is not opened, you are always simultaneously safe and not safe.
Often people think that they can just use the equipment with the chassis opened and they can be sure they are safe...but this isn't true, because when you look away to change the EQ, the safety bond goes away and doesn't go away.
Like the concept of simple addition to a drummer, it's neigh incomprehensible.
dogears
« Reply #15 on: November 09, 2019, 04:56:16 PM »
;D  ;D ;D ;D
JohnRoberts
« Reply #16 on: November 09, 2019, 05:39:47 PM »
Schroeder's cat is surely dead from old age by now....   ;D
« Reply #17 on: November 10, 2019, 07:17:26 PM »
Mr Schrödinger drowned it after it kept sneaking in the house,  eating his cat's food, then pissing in the kitchen,.
Or did he?
boji
« Reply #18 on: November 10, 2019, 07:35:31 PM »
Worse than that, if you're by all counts not safe but then as the hot signal passes down the wire you somehow become safe, the ground short will go back in time and also drain properly to comply with the change in circumstance.  :o
« Reply #19 on: November 11, 2019, 03:24:39 AM »
Yeah, but, if you reverse the polarity, quantum will ensure the money you paid for it is removed from the supplier's bank account and placed in someone else's at random.
Last post November 22, 2004, 12:59:20 PM
by gang of elk
Last post January 03, 2005, 09:51:02 PM
by bluebird
Last post September 25, 2006, 12:27:54 AM
by Michael A
Last post August 08, 2012, 11:52:58 PM
by ricardo
