Diode Ploarity over relay coils.
« on: November 10, 2019, 12:43:38 PM »
This I can possibly almost answer myself but i want to be reassured im right,.
Im running relays with a negative supply. The safety diode should be facing the voltage source if run on a positive supply but should it be reversed when run on negative?
Emil
Khron
Re: Diode Ploarity over relay coils.
« Reply #1 on: November 10, 2019, 01:54:46 PM »
The cathode ("band" end) should be facing the most positive voltage - in your case, i guess that would be ground?
The anode should be then facing the more negative voltage.
The other way around, the diode would be forward-biased, and flow a lot of current from ground to the negative rail (through the transistor that switches the relay on).
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
Last post December 18, 2010, 10:57:46 AM
by electrochronic
Last post January 25, 2013, 10:27:16 AM
by Sean Halley
Last post August 14, 2018, 05:01:56 AM
by abbey road d enfer
Last post August 17, 2019, 08:28:18 PM
by JohnRoberts
