Theres not much in the way of ADC out there really ,
There is one old TI evaluation board that looks good , PCM4222EVM ,
It will do up as far as 192khz , every parameter is adjusted by jumper old style
Uses high grade op amps and keeps everything balanced right up to the ADC inputs .
Its around a long long time and doesnt support higher sample rates , theres also around 100 jumpers to set all the parameters:(
It is available from Alied for 175$
TLV320ADC6140 quad-channel 768-kHz Burr-Brown™ audio ADC evaluation module is also an option , it comes with an xmos usb controler card , every parameter is controlable in a very comprehensive software called pure path console.
http://www.ti.com/lit/ug/sbau335/sbau335.pdf the unit can be configured for many different uses
You get either balanced or unbalanced inputs 2v(1v) basic sensitivity, no fancy op amps up front . 200$
A 30$ USb Xmos board and one of the TI ADC chips on a break out board might do more or less the same job ,but without the additional software that allows full access to the dsp /mixer settings easily.
Im very tempted to try one of the E1DE Gen3 DAC's and use it as source for test signals, with the calibration available on the chip itself via the app it should be able to offer up an extremely accurate low distortion test signal to well beyond 100khz.
