Icegoldnixon
- Joined
- Feb 3, 2015
- Messages
- 79
Hi All,
I've had a PA/guitar amp project sitting around for several years. My grandfather and I did some work on it, but it was all chopped up when we got it. After it died for a last time, I completely disassembled it for a total rebuild. And disassembled it has stayed, as life has been busy and my Grandfather can't really help me any longer.
Lots of uncertainties have kept me from starting the project, since I want to do a good job and don't know tube gear that well. To boot, the voltages in this old amp are very dangerous so I don't want to be fumbling around. I have a lot of questions, but the main one is about the power supply. In the schematic, there's a 10/10/10 filter capacitor that's (apparently) rated at 600V. I cannot source any 600V multicaps, which I would prefer to use to make the layout easier. Do you think the 600V rating is necessary? 450V caps are much easier to find.
(Also, I've thought about creating a separate power supply to make room in the chassis. In that case, I'd just use the axial caps. But I suspect that would create trickier design decisions than I'm prepared to solve. I'm also thinking of removing a few channels from the preamp, maybe that would lighten the load on the PS? ) Thanks!
