Phrazemaster
Hi, I'm cobbling up a small DC PSU to run a couple LEDs in a compressor. There's a transformer that is supplying 6.3V AC and it's rated at 2A.
I anticipate using no more than about 100mA for the LEDs total. I want to get a little bridge rectifier from mouser, and I see there's all kinds of forward current (If) ratings. Would I be OK to use anything 2A and above? I mean, couldn't I even get away with 0.5A?
I don't know if there's any kind of surge to consider, etc.
It's not the expense - we're talking pennies difference between the lower current ratings and higher ratings - it's the form factor. The lower current rated ones are smaller which is attractive where space is limited.
I've tried googling this sort of thing, but end up mired in endless graphs and discussions, and the occasional scolding of others, but little practical simple info.
Thanks for your thoughts.
Mike
PS - I know I could probably get by with just a single diode to run the LEDs (plus resistors of course), and I've been told there's no flashing pulse due to the extreme ripple, but I'd just rather make a small little DC supply, as much to learn as to mitigate any possible strobe effect...
Mike
