Aleguitarpro
XLR bottom connectors SDC mics
« on: November 17, 2019, 10:26:01 AM »
Hi
I need an help to source the XLR bottom pin parts of small diaphragm condenser mics.
I need to know if something already built is available for sale from suppliers instead of starting to build something custom maybe with a "cable" standard male XLR connector and an aluminium tube.
I need to mount this part in pencil bodies of about 14.5mm of diameter (akg 451 dimensions)
bremusound
Re: XLR bottom connectors SDC mics
« Reply #1 on: November 17, 2019, 12:08:13 PM »
There are cheap male / male XLR adapters available.
Like  these:
https://www.amazon.com/Hosa-GXX-144-XLR3M-Gender-Changer/dp/B000068O4J
Cut them in the middle and you have two connectors which could fit and look nice.
Aleguitarpro
« Reply #2 on: November 17, 2019, 04:07:28 PM »
Like  these:
Thanks for answering.
I already though about this solution... You are confirming that probably is not bad as idea.
I found these products:
https://www.thomann.de/it/neutrik_nm_3_mxi.htm
https://www.thomann.de/it/sennheiser_umbaukit_f_md_441.htm?o=3&search=1574025155
But it's impossible to find their drawing with measures.
Probably I'll go for the diy solution with the adapter barrel
Ricardus
« Reply #3 on: November 17, 2019, 07:21:09 PM »
Just buy a Switchcraft male XLR connector. That part you seek can easily be removed from it.
Audio mastering for hire..
bremusound
« Reply #4 on: November 18, 2019, 06:52:43 AM »
Look here
https://www.neutrik.com/media/8710/download/nm3mxi-2.pdf?v=1
for some imformation abuot the Neutrik XLR thing you found at Thomann.
To me, the adapter solution looks better but maybe the Neutrik works better for you!
Aleguitarpro
« Reply #5 on: November 18, 2019, 10:52:58 AM »
Look here
Marik
« Reply #6 on: December 17, 2019, 04:23:06 AM »
Hi
We build those parts all day long out of Stainless Steel, or Aluminum. The cheapest option for you would be mating one of the aforementioned XLR barrels (not Neutrik, but Swithchcraft style) with your tube. Still, you will need a lathe to turn the end down and seamlessly mate...
Best, M
« Last Edit: December 17, 2019, 04:30:27 AM by Marik »
Samar Audio & Microphone Design
www.samaraudiodesign.com
The Art of Ribbon Microphones
Last post September 03, 2008, 05:49:43 PM
by Jidis
Last post January 24, 2006, 10:31:11 PM
by Kev
Last post March 09, 2007, 05:39:46 AM
by clintrubber
Last post May 19, 2009, 12:41:53 AM
by 1954U1
